When configured for advertisement on Ethernet (PoE) or PoE+ ports, this TLV advertises the device type, power status, power class, and pin pairs used to supply power.
The device type field contains a binary value that represents whether the LLDP-compatible device transmitting the LLDPDU is a power sourcing entity (PSE) or powered device (PD), as listed in Power Management TLV Device Information.
| Value | Power source |
| 0 | PSE device |
| 1 | PD device |
| 2-3 | Reserved |
Control advertisement of the power via MIDI TLV.
Refer to for Configuring Avaya-Extreme TLVs and Configuring LLDP MED TLVs more information on power-related TLVs.
